Installation & update
Complex Profile Window/Door Error
I am having a problem with my complex profiled walls. When I try to put a window in I receive a warning as follows:
Index value greater than array dimension at line 158 in the Master script of file wa_trim_us_10.gsm
Has anyone seen this warning before? I have put this same door in a normal wall and it works fine. I have also tried to adjust every parameter of the door and still no luck. I get the same error with windows. They show up on the floor plan as the blue dot of death. Any suggestions? Thanks in advance.
13 REPLIES 13
Dwight
Please post an image....
Dwight Atkinson
Folks,
After being so confident on my windows and doors working, I realized that in my half log profiled walls they did not. They placed into the walls fine but in section/Elevation/3D the walls themselves disappear leaving only the window/door in its place. Attached is a picture.
Attached are the log profiles that disappear when I put a window/door in them. In 3D as soon as I delete the window/door the wall pops back in. I have tried everything I can think of. Am I doing something wrong? Maybe a bug?
No bug, fixed one problem. I had a 1/64" gap between the logs to make the log profile show up on elevations instead of drawing them in later. This made each log it's own seperate wall. Silly on my part, I should have known it would do that. I still cannot get AC10 doors/windows to work in the walls but at least my Log home solutions windows/doors do now without making the walls disappear.
