Installation & update
Crash bug report
VladGoo
Hello!
I’m using a MacBook Pro 16” 2019 intel base and Sonoma OS. When I want to edit a text my program crash and open a bug report window. I have AC27 whit hotlink update.
Thank you!
VT
Operating system used: Mac Intel-based 4010
Editing the text is a known problem for 27 on Sonoma.
Until it is fixed, I believe you can turn the CAPS lock button off when editing text.
The idea of the bug reports is that you take note of the bug number and send it off.
Then follow up with you local Archicad Support, quoting the bug number and asking them to investigate.
They should then acknowledge the problem, and tell you a solution/workaround, and escalate the issue to Graphisoft HQ if need be.
1 REPLY 1
Setup info provided by author
