tomyg
Crash when populating Sections on sheets
I seem to be having a consistant problem on a staff members computer. Keeps crashing on some bigger residential jobs when we go to the sections layout/sheet
AC24-2021-02-17-01-11-10-1046
3 Replies 3
tomyg
sorry! i just realised i posted this into the wrong section.
No problems - I have moved it.
I have no de what the problem is though.
The actual sections are fine, just a problem when you go to that particular layout page?
Does it help if you create a new page?
Minh Nguyen
Dear Tomy,
Thank you very much for the report and I am very sorry about the experience!
Based on the crash report, I could see that you are still using the initial release build of Archicad 24 (3008). I would like to make sure that the issue no longer happens with the latest public update for Archicad 24 (currently 4018). Could you update your Archicad installation and let us know the result? Thank you very much!
Best regards,
Minh
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
