Installation & update
Curved walls not showing in Elevation
I'm having a problem with my curved wall edge not showing in the elevation window. I've tried everything and nothing fixes the problem. As you can see from the 3d image there is a wall there.
Any suggestions?
[img]
[img][img][/img]
4 REPLIES 4
let's see whether I can add the images!
here's the problem elevation image
here's the plan view showing the curved walls
Miquel Garcia
Are all your walls in the same layer? If you use view sets with layer combinations perhaps the layer combination assigned to your elevation view don't include all the necessary layers.
Miquel
Capella & Garcia Arquitectura
AC18 - AC21, iMac 27" 3.1 Ghz Intel Core i7, 16GB Ram, OSX 10.13.1
