2015-02-18 07:55 PM
2015-03-06 12:32 AM
abelowde wrote:If you have several instances of ArchiCAD open, when the last instance is closed, the work environment will be remembered from this one, not all the other instances you had open previously.
Hi all,
How can I fix this problem? I want to stop having to select my profile all the time! If setting the default isn't working, what will?
Thanks
