Too Long
Design Options Palette
I dont have the option to show the Design Options palette or from either the Document or the Windows tab.
What do I need to do to have it available to me?
AC26 AUS Full
1 Solution
Your signature shows Archicad 26, but I assume you are using 27.
I would guess you have a Work Environment from 26 (or before).
The new commands in menus will not show if that is the case.
You will need to add the new commands yourself, or switch to a standard 27 WE and make you own personal customisations again.
Go to post
2 Replies 2
Too Long
Yep, you nailed it, thanks
AC26 AUS Full
