TomWaltz
Details from an invalid PLC
Last week, we had a user open a PLC file that was not valid. (She had changed her workspace, and the ID was not longer the same).
In the invalid PLC, she created nearly 2 dozen new details, and worked on them.
Is there any way to bring in the details as a group, instead of copy/pasting them in one by one?
Tom Waltz
10 Replies 10
__archiben
can you save both as PLNs and merge the invalid file into what was the PLP? bit dicey . . .
~/archiben
b e n _ f r o s t
TomWaltz
That would work for the plan/model changes, but "Merge" does not import detail windows or the 2D content drawn into section windows 😞
Tom Waltz
Djordje
Forward merge does ...
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
TomWaltz
"Forward merge?"
Can you elaborate on that? I don't think I have heard of that one.
Tom Waltz
Djordje
TomWaltz wrote:
"Forward merge?"
http://archicad-talk.graphisoft.com/viewtopic.php?t=3791
http://archicad-talk.graphisoft.com/viewtopic.php?t=973
Djordje
HP Omen
TomWaltz
This sounds like an interesting procedure, but how does it actually copy details from one file to another? How would it manager to re-vailidate a PLC, or copy details from the invalidated one to a valid one?
It sounds more like a method for cleaning up corruption in a problem file.
Tom Waltz
Tom,
It sounds like the easiest thing would be to publish the details as modules, and then merge them into to main file.
Aussie John
Matthew wrote:
Tom,
I agree. The trick is to catch the generating section and stop it before it can build. Then you can select all to pick up the added bits of information.
Cheers John
[/size]
TomWaltz
It seems like the publishing, merging, unlinking, and replacing all the detail markers is still a lot of work.
I've long been pushing for the ability to import details from one file to another, and I think this is the first error-correcting method I have found for it. I always thought of it as a way to re-use data from previous projects.
Tom Waltz
