I'm desperately trying to find a solution to my problem:
Im using Archicad 16 (hotfix3 ok) on a new pc recently bought to replace an older one
When i try to open my documents, i've got an error talking about a read/write error... see the screenshot: I'll translate: 'Archicad has detected a read/write error on the disk and is gonna exit.'
=> thus, Pc is new, this is an hp workstation, SSD sata drives (RAID1), quite plan new and no error detected. Files failed to open, whether it's located on a server or locally. Full rights have been given to the file (everybody => full control) , no specific user rights with lower rights.
Our local reseller told us he couldn't help, so someone here around may have an idea?
more specifications: documents use the MEP library.
the OS is windows 7 64bits pro.
all system requirements are made.
please let me know if you have an idea.
Regards.
