Installation & update
Edit GS Community Signature - Where?
Aaron Bourgoin
can't find the spot to update my signature on this new board. Where does one do this?
Think Like a Spec Writer
MacBook M4Pro
AC4.55 through 29 / AC29.0.2 USA
Rhino 8.26 Mac
MacOS Tahoe 26.2
20 REPLIES 20
DGSketcher
Legend
@Gordana Radonic Here's another to add to the problem list. I have received a Private Message, none of the options to mark it as read are operating in Safari.
@DGSketcher I think this is connecting to the generic issue with Khoros communities in Safari (what you and @Karl Ottenstein  reported before). Karl found a possible reason, see:
"https://support.apple.com/en-us/HT204098
Opening the Community in a Private Browsing window works fine! So the issue is somewhere in cache/cookies/etc."
I reported this to Khoros, we are waiting for their response now. I cross my fingers that after the holiday season they will progress faster. Could you please try if the above workaround helps you too? (So just that we see if this is the same thing or not.)
NoƩmi Balogh
Senior Community Expert, Admin
@Noemi Balogh I updated to Mac OS 11.6.2 and Safari 15.2 last night. Unfortunately no joy in changing to Private Browsing on any of the page sub-menu options.
Sad to read this. šŸ˜ž I'll report this to Khoros too.
NoƩmi Balogh
Dave Jochum
Really don't like this forum UI. Is the signature currently not available?? It's sure not in MY SETTINGS > PERSONAL INFO.
Dave Jochum
J o c h u m A R C H I T E C T S http://www.jochumarchitects.com
MBP 16" (M1 Max) 64 GB•OS 15.6.1•AC 29 Silicon (latest build)
You don't see this?
@Dave Jochum It isn't the best presented format. I was originally caught out that the list on the left of Barry's screen shot is a menu to display different items on the right. As you can see "Personal Information" will bring up the "Signature" box
Dave Jochum
Thanks Barry and DGS, I see it now. Incomplete navigation info and poor UI design.
I now do not see a preview button for signature editing nor formatting info.
Dave Jochum
Formatting is apparently a Moderator privilege! Work in progress for us mere mortals to have access...
Just use an on-line editor and copy & paste the code.
That is what we do too.
https://html-online.com/editor/
