Error Code:-1. I can't make renders in archicad.
When I push the photorender button. Apears a windows which says. Error en el manejo de Pantalla. Codigo de Error: -1
I try to figure it out what was the problem and i discover that this error only appears when I use a template that I make to work. But when I use the defealltud template there is no problem. This is situation is giving my problems because I cant render any file made with this template.
I tried to send a copy of my template but for some reason the forum dont allowed that
1 Reply 1
Also It says appears a little windows which says
ALERTA! Llamada de funcion invalida en el motor
TRANSLATE:
ALERT! Function call invalid in the engine
I still can't make renders. I think the problem is relatet to the template but still I dont know what it is
