Error: INVALID FUNCTION CALL IN ENGINE
Hi, sorry for my english, but i have a problem. When i'll try to render, Archicad 13 on W7 (64) says INVALID FUNCTION CALL IN ENGINE.
Please, help me to solve this trouble
4 Replies 4
Please post your answer if you found it
Found the solution, you need to go to the Photo Renderings settings and there change the size to whatever you need.
I would suggest you size to 3d windows just to make sure you have the proportions right and then downscale.
Hmm... I have the same problem but the solution doesn't work for me... 😞
18 months later....I found the invalid function call box popped up when I was rendering with Lightworks and the camera distance to target was 1 inch or less (I like to end flybys looking straight down at the target).
