Warning! Errors &&^%#&$^%#@&^
Anyone seen these before?
Anyone have any suggestions on how to fix this?
Happens whenever I try to render anything in the file: 'Invalid function call in engine' comes first followed by his friend.
Mike
4 Replies 4
For some reason the issue suddenly went away.
The last thing I changed before it righted itself was the size of the render window, somehow it was set at 32x32, but when I reset it at 32x32 it did not result in the same errors. So I dont really know what happened.
New issue now: I have been working along in a different project, placing a lot of IE markers for wet area details etc. I like to use marker 6 with the solid coloured triangle around the circle of the marker head. Out of no where, I realise the marker head is not showing black any more, but is now showing white, on further inspection I realise that all background fills for all elements/objects/walls are now acting as transparent!!!
What the hell is this?!?!?!?! I cannot afford to lose any more time on this, so please if anyone has any ideas, help me out.....
Mike
David Maudlin
Mike:
Look at Model View Options > Override Fill Display > Override Drafting Fills.
HTH
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Thanks David,
I did check this out before, but no luck!!!! I cant figure it out!!
Im worried the file is corrupted as I didnt do anything apart from insert another IE marker, then boom!!! all walls, columns, markers etc now have transparent background fills!!!
Mike
OK im only laughing at this because I thought this file, which has had 160+ man hours put into it, had become corrupted!!!
Solution: turned trace off!!!
HAhahahahHAHAAAAAAAAAAHAHHAHAAA, phew!!!!
Mike
