Archicad and Logitech MX Revolution Mouse bug
Hello guys,
I have this problem.
Usually this happens after spending time in the program and more commonly when ALT+TAB-ing alot. My drag and measure line disappear. I am talking about the ones that appear when you try to move an object and that are connecting the "before" and "after" position of this object. Also the "after" position doesn't show up too.
To better illustrate my problem I have included screen shots (they are taken with Windows XP, my system is Windows 7 now):
Drag:
1. Normal Drag
2. Buggy Drag
Measure Line:
1. Normal Measure
2. Buggy Measure
This only happens when using my Logitech MX Revolution mouse, after switching back to my old PS2 mouse everything is ok.
If anyone has an idea about this whole thing I will be very grateful.
All info on this topic will be appreciated.
Thanks in advance.
My PC:
CPU: Intel Core 2 Duo E6600 2.4 Ghz
RAM: 2 GB DDR II 800 Mhz
GPU: ATI Radeon HD4850
OS: Windows 7 32-bit Ultimate with latest updates
Arhicad 13.0.0 Build 3259
3 Replies 3
Most of the time this is due to graphics card driver problems.
Try to update those drivers first.
I am using the latest Catalyst driver (10.2), the latest Direct X and the latest Java.
I am positively sure that the problem is connected with the MX Revolution mouse because when I disconnect it, and plug in my PS2 mouse problems disappear.
I think this has something to do with the Logitech drivers (SetPoint).
I have contacted them too.
Please advice further.
bump
