Installation & update
Errors occured during the last operation.......
Arcadia
Occasionally I get a job where I get this dreaded message when going to 3D window or elevations or sections. It usually doesn't seem to affect anything but its really annoying and slow's me down and seems impossible to track down a cause for. Its probably an error with a 3D part but I can never seem to figure out which part. Is there any way I can figure out what it is or even turn off the message? You would think AC would know where the error was and tell where it could be found.
V12-V27, PC: Ryzen 9 3950X, 64g RAM, RTX5000, Win 11
1 REPLY 1
Arcadia
Don't worry I just figured out that I could enable error reports and this identified the 3D part that was causing the problem.
