mike
when you say that all computers are running 10.2.8, do you mean that the server is running OSX server 10.2.8 as well?
our office has a 1GHz X-serve with OSX 10.2.8, 512MB ram. 95% of the office machines are running 10.2.8 as well. whilst there is long wait for library load times and sending and receiving to large files, actually navigating the files and folders from within archiCAD dialogue boxes is as fast as all other apps.
does your network use a switch or a hub? what speed is it? are the files and folders that archiCAD is navigating in a different share point to files that the others apps may be browsing? are you running a RAID setup on the server, if so hardware or software RAID?
have you cleared out all archiCAD prefs and tried from scratch? once you have navigated to the file, does it save quickly once open, or does the slow down affect the actual opening and saving times of the files as well?
~/archiben
	b e n _ f r o s t
