Font not appearing on Mac
Jackcowdrey
Hi all,
I alternate between using a Windows Desktop in the office and a Mac laptop at home. We use two fonts, Lyon Text and Futura No2 D. Even though I have both fonts installed in my Font Book on my Mac, Archicad won't recognise them on my Mac and give me the bracket around the font eg [Lyon Text].
Anyone else have the same problem or know a potential solution?
Thanks
Miha_M
That is an old problem and I remember seeing a working solution:
Replacing missing fonts between Macintosh and Wind... - Graphisoft Community
I don't know if this one still works?
| Archicad 4.5 - 29
| HP Z840 | 2Ɨ E5-2643 v4 | 64 GB RAM | Quadro M5000 | Windows 10 Pro x64
7 REPLIES 7
DGSketcher
Legend
The fonts may not be compatible with Mac / Archicad...
Missing Fonts
Do they work in other Mac applications?
Thank you for your response. Yes the fonts work in Archicad on Windows, and the fonts work in other Mac applications such as Keynote, Pages, Microsoft Word (for Mac).
DGSketcher
Legend
See if this thread helps...
Missing font remap
The font is open type format, which according to that thread suggests that it is cross platform.
Miha_M
| Archicad 4.5 - 29
Hi Miha_M,
This worked a treat! Thanks
Da3dalus
We're gradually adopting Windows and getting rid of Macs in my office (much to my chagrin), and we have to stay vigilant on this.  I keep the improved XReadCfg.txt file on a server so it is always installed on new computers and new. versions of Archicad.  Unfortunately, every time you run a Hotfix/Build Update, it overwrites this file, and you have to redo it on every Windows computer.  Also, on Windows, it's in the C:\Program Files folder.  This generally requires admin permission to change, and it gets more difficult with every few Windows updates.
Chuck Kottka
Orcutt Winslow
Phoenix, Arizona, USA
ArchiCAD 25 (since 4.5)
Macbook Pro 15" Touchbar OSX 10.15 Core i7 2.9GHz/16GB RAM/Radeon Pro560 4GB
