Framing Roof Problem
Using Archicad 14
My framing is attaching to my roof membrane and is keeping my roof framing from gavitating to my top plates. I need to reverse the roof membrane with framing.
I use the roof wizard which works perfect, except the fact that its on top of the roof material instead of underneath resting on the plates like it should be. If I turn off the roof material layer, roof framing still does not drop to plates.
Does any one know how to fix this, or suggestions how flip this around. Would very much be appreciated!
To see 3D picture click on download pdf. (all the way to the RIGHT)
Ry
0 Replies 0
