2007-12-09 06:15 AM
2007-12-09 07:30 AM
2007-12-09 09:19 AM
2007-12-09 03:24 PM
Also , in your view map right click on the view you want to reference. There is a pop up menu that will allow you to use that view as a trace reference.Not just views - but also viewpoints and layouts. All can be trace references.
2007-12-11 08:12 PM
2007-12-11 08:56 PM
DataChris wrote:GS needs to get its act together on a number of things, but this is not one of them. If you had done a search in the Help menu on "Trace" you would have found exactly what you needed. Further, if you need to find or add something in a menu, use the attached. You also could have used the Palettes DBX to bring up the one for Trace. Perhaps a little training would be useful? Many resellers have specific AC10 to AC11 upgrade training.
Graphisoft needs to get it's act together on changes like this.
2007-12-11 09:59 PM
DataChris wrote:Of course! You can hardly expect your customized WE (work environment) transferred from the previous version to suddenly magically contain all the new features of a new program version!
Trace did not exist in any form under any menu or work preference etc etc etc. The only way to have it appear was to apply all the default AC11 work environments and then manually update them with my shortcuts etc.
2007-12-11 10:41 PM
2007-12-11 10:50 PM
DataChris wrote:they didn't exist in 10 because it is a new 11 feature. they do exist in 11 regardless of whether your WE has them enabled. you just needed to do as link suggested. when you import your 10 work environment for the first launch archicad
Richard, I performed that search. NOTHING came up. There was absolutely no reference to trace in any form through any menu, help screen, search, etc. etc. Again the only way to get them back was to reset the defaults.
I would've simply added them to my work environment if it were possible but they did NOT exist.
2007-12-11 10:57 PM
archiben wrote:
...they do exist in 11 regardless of whether your WE has them enabled. You just needed to do as link suggested.
