2007-12-09 06:15 AM
2007-12-11 10:59 PM
2007-12-11 11:01 PM
DataChris wrote:So when you use the Help Menu, you don't get this?
Richard, I performed that search. NOTHING came up. There was absolutely no reference to trace in any form through any menu, help screen, search, etc. etc. Again the only way to get them back was to reset the defaults.
I would've simply added them to my work environment if it were possible but they did NOT exist.
2007-12-11 11:10 PM
DataChris wrote:mate. they did. you're not understanding the WE concept.
I don't know how else to state it but they DID NOT EXIST in my copy of 11 in any form. Period.
I don't know if it's a bug or just some tweaked out reality on my installation/mac/etc but they did NOT EXIST in any form and could not be added without resetting the defaults.
2007-12-11 11:25 PM
DataChris wrote:That's just it. If they "
2007-12-12 06:13 PM
there is a list of ALL commands - they are built in to archicad, right? and then there is your work environment - this shows the commands that you have selected to make visible. reset 'switches off' all commands that you were previously using and 'switches on' the default set of commands.
when you open the WE settings dialogue and go to the 'Command Scheme'>'Menus' tab you will be presented with two lists: the left hand side contains various permutations of command lists, the right hand side YOUR selected command list. switch the left hand side to 'Show all commands' or 'Show all commands by theme' and add them to the right-hand side where you want them.
because you imported your 10 work environment, archicad only 'switched on' the commands that were present in archicad 10 - more specifically, the commands that you had switched on in AC10. that is why they didn't show in 11.
~/archiben
2007-12-12 06:17 PM
Richard wrote:Exactly.
2007-12-12 06:26 PM
2007-12-12 06:30 PM
Thomas wrote:
The only (but a bit far-fetched) explanation I can figure is that you have several AC versions installed, and the links somehow have gotten screwed up. Example: I've had issues when I've had both the INT version and the localized SWE version installed, both in the Graphiosft folder. A complete re-install should fix this, but I'd recommend uninstalling all older versions or at least re-naming their folders first.
2007-12-12 07:30 PM
DataChris wrote:
Hmmm not so far fetched. AC 11, 10, 9, all running.
