Glitch or new function I dislike?
Has anyone else noticed this in v14?
When I click on the layers in the info box, the first time I look I don't see the intersection groups. The second and subsequent times I do. I'm hoping this is some weird 'convenience' that I can override. Has anyone else seen or noticed this?
Jared Banks, AIA
Shoegnome Architects
12 Replies 12
And the second time I click on the same object type.
Jared Banks, AIA
David Maudlin
Jared:
I just tried this and got the same result as you, I had not noticed before, looks like a bug.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Rod Jurich
David, Jared, same here.
Rod Jurich
AC4.55 - AC14 INT (4204) |  | OBJECTiVE |
Must be a Mac only "feature".
No problems here on Windows.
David Maudlin
I reported this bug to Graphisoft.
All,
Running AC 14 on Windows 7 on 64 bit PC & do not report the problem.
Achille Pavlidis
I use AC 14 on mac, and I do not have this problem
Mac OS 26.4 | AC 29.2.1 INT 5101 FULL
Rod Jurich
Achille, I first thought this too.
Did you select from the INFO BOX layer box.
Because if you select a shortcut to the layer setting itself it is ok.
The bug manifests only when you select from the info box.
Rod Jurich
David Maudlin
Also when using the Layer selection pop up in a dialog box.
