VGDD
Drawing placed on master layout not clipping properly
Occassionally I need to crop a drawing's boundary when placed on a layout to exclude some items ( the grid number references as an example on the attachment) however, archicad 27 doesn't do this properly. It only crops the outside frame extremes based on regular rectangle. Is there a new function I need to check or is this a glitch as currently I'm having using masking shapes. Never had this issue since v.11 when I started using AC.
Archicad 11 - 27
Windows 11 Home
11th Gen Intel(R) Core(TM) i7-11700K @ 3.60GHz 3.60 GHz
32.0 GB
3 Replies 3
VGDD
As an update, it appears that when I print to PDF the items outside the cropped frame doesn't print, which is good, but I'd still prefer to be able to hide them. Sometimes, I have to do some complex cropping when I place 2 floorplans together due to split floor plans / offset FFLs and this makes life harder.
Archicad 11 - 27
Windows 11 Home
32.0 GB
Botonis
Mentor
In this Archicad universe, seems you are not alone!!!!!!!!!!!
https://community.graphisoft.com/t5/Documentation/BUG-in-Layouts-AC27/m-p/576125
Greetings to all.
OcieWisozk
Any update?
I also faced this clipping problem but now on my side, everything is working well for me. thank you everyone for your suggestion. The quest for the perfect research paper is a journey every student embarks upon. The CustomWriting beckons with promises of expertly crafted papers. Intrigued by the possibility of a seamless research paper purchase, I'm gearing up to explore the offerings and see if they align with my academic needs. And when I tried them, it was the best of all experiences i have ever had. Thank you.
