rengarch
HP 130nr
My trusty HP 230 plotter is on the brink and I need to replace with another reliable plotter. Does the HP 130nr work with MAC OS 10.3.7?
Or should I buy the HP 430 connected to a HP Jet Direct box?
Thanks.
Rita
Rita MF Eng, AIA
iMac 27" 3.5 GHz Intel Core i7
NVIDIA GeForce GTX 780M 4096MB
MAC OSX 10.11.6
Archicad 20
1 Reply 1
Stress Co_
Rita:
I had an HP130nr, but traded it in for an HP 110 plus nr. Both worked fine with OS 10.3.6. I’d recommend the HP110 plus nr.
The 130 is geared more for users who print a lot of photos/color graphics. It uses dye ink, which is not compatible with T-bond or Vellum papers. (I still blueprint my plots).
The 110 + looks identical, uses a pigmented black ink and only has three colors (the 130 has five, plus black). The 110 was a bit cheaper too. Use the money you save to buy a stand.
The only issue I had was a missing Mac driver disk but I download it from HP’s site.
I’m now using OS 10.3.7 (connected via Ethernet cable) with no problems.
Good luck,
Marc
Marc Corney, Architect
Red Canoe Architecture, P. A.
