Having trouble with the 966 Hotfix...
Downloaded the AC10 966 hotfix, but it gives me the message "No appropriate ArchiCAD is found in this folder" when I browse to the folder the app and it's support files are kept in. Anybody got any ideas? Don't know if this has anything to do with it, but my original AC10 install disc says: AC10-USA-C2001
US Version (build 815)
When I do a get info on the AC10 App. it says:
10.0.0 v1 INT (815)
I downloaded the USA version of 966.
G4 1.4 MHz
1 GB ram
10.3.9
5 REPLIES 5
You want the 'ArchiCAD 10' folder. Not 'Graphisoft', not the ArchiCAD 10 app. It should work.
10.0.0 v1 INT (815)
It always says INT. No worries, just a quirk. It should say USA in the about ArchiCAD screen.
James Murray
Archicad 27 • Rill Architects • macOS • OnLand.info
Bob Moore
Thanks,
I got the same message.
AC 7 - 27
iMac 27"
Mac OS Sonoma 14.0
3.1 GHz 6-Core Intel Core
32 GB 2667 MHz DDR4
Radeon Pro 575X 4 GB
Well, downloaded the fix again, picked the ArchiCAD 10 folder (I did that last time, too). Same message - says no appropriate ArchiCAD can be found in the folder. Anything else you can think of that might be causing it?
David Pacifico
Did you close out of Archicad before installing the HotFix?
David Pacifico, RA
AC27 iMac i9, 32 gig Ram, 8 gig video Ram
Yes, closed out of everything. Only thing running was the OS and the installer.
