Help | Check for updates doesn't work
Hi All
I go to
and it doesn't work. Nothing happens...
Does any one have any ideas?
Win XP pro, sharing a DSL connection, and using Windows Firewall
Thanks in advance, Mat
6 Replies 6
Works o.k. here. Can you be more specific about what is happening / not happening? (I'm thinking for others, I will be no help with this, I promise).
Hi Stuart
Like I said, nothing happens. It's as Dwight said; "light's are on, but nobody's home". Select the command, and nothing.
Is there some setting that disables this feature? Does the Windows Firewall disable it?
Djordje
mat wrote:
Hi Stuart
It is possible, but in that case you should get a warning. Check your firewall settings and allow access for Graphisoft sites. They are safe, AFAIK.
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
__archiben
it should launch your default browser and connect to here:
http://www.graphisoft.com/support/archicad/downloads/update.html?_submitted=1&_sessionid=&version=10...
(make sure the platform, version and build number are applicable to your specific set-up before linking in!!!)
are you using a non-mainstream, weird web browser?!
~/archiben
b e n _ f r o s t
Yeah I use Opera as my default browser.
Thanks for your help. I used the link you posted.
Djordje
Turn to IE for the automatic Graphisoft stuff ... Safari on the Mac OS.
Djordje
HP Omen
