Hotfix #2 (build 2325) for ArchiCAD 12 is now available
Greg Kmethy
Dear ArchiCAD-Talkers,
Hotfix #2 (build 2325) is now available for INT, USA and GER versions of ArchiCAD 12 through the automatic update system, or by clicking 'Check for updates...' in Help menu. This Hotfix can be applied to any previous build of ArchiCAD (2156 or higher), and any license types (FULL, EDU, TRIAL)
Please take a moment to read the Release Notes, especially if you are using Hotlinks, as there are important changes concerning the layer management in Hotlinks.
Greg
Gergely Kmethy
VP, Customer Success, Graphisoft
22 REPLIES 22
How do you check for current version now ?
I don't see it in the help menu anymore.
Hello Steve,
You seem to be missing the last two items in the Help menu.
see attached
Peter Devlin
Thanks. I had to go to the Work Enviroment and add them back into my menu. They were missing when I open up the default ArchiCAD 12 Template.
