How can I export all my ArchiCAD settings ?
Is it possible to export all my ArchiCAD settings (keyboard shortcuts, palettes shapes, layout)?
Since I have to migrate on newly installed OS it's actually waste of time to set all these things all over again.
I see that ArchiCAD stores some settings in: Documents and Settings\....\Application data\ Graphisoft\. If I backup this folder and I’ll overwrite newly installed one – will it be enough to restore all my settings ?
Would you like to help me ?
3 Replies 3
David Larrew
It is supposed to work like you described. The user/program setting should be stored in the .PRF files. But in our experience, we found that not to be the case (at least in AC8.0 - AC8.1r1). Maybe someone can verify if AC8.1r2 is any different.
David Larrew, AIA, GDLA, GSRC
Architectural Technology Specialist
a r c h i S O L U T I O N S
WIN7-10/ OSX 10.15.7
AC 5.1-25 USA
Link
I think the difference is that AC8 stored the PRF files at:
C:\Documents and Settings\<username.\Local Settings\Application Data\Graphisoft
(You will need to have 'Show hidden files and folders' turned on in your Windows OS: Tools>Folder Options>View> to see this folder)
While AC8.1 stores them at:
C:\Documents and Settings\<username>\Application Data\Graphisoft
I haven't tried copying AC8.0 prefs to AC8.1 prefs. I'd be curious to see how it works.
Link.
Is there a way to change where AC 8.1 stores prf files?? Maybe regedit?
I would like to store preferences in a removable HD... Any idea?
Thank you,
Ricardo
