2025-02-25
11:14 PM
- last edited on
2025-02-26
01:38 PM
by
Tutor is using ArchiCAD 28, CI Tools installer is showing that Cadimage Doors and Windows is installed however Tutor is reporting that it is not showing up inside ArchiCAD 28 under Doors and Windows Default settings.
Operating system used: Windows 11 24H2
Solved! Go to Solution.
2025-02-26 01:26 AM
Hi @SIT-ITS
Have you loaded the Ci Tool Library Packs (new workflow since AC28)
https://cadimage.zendesk.com/hc/en-us/articles/10886875093391-Library-Loading-in-Archicad-28
If you have any other trouble reach out to the Ci Tech team via email at nz.support@centralinnovation.com
2025-02-26 01:26 AM
Hi @SIT-ITS
