Hello LizFortune!
Pgon
means Polygon. You have got an Object that is not behaving well in your ArchiCAD File. My advice: Make a copy of your File by Choosing
File - Save As
. Then use the Copy and experiment a little. Remove Objects one at a time. Go to 3D every time. In the end you probably will come to a point where you will
not see the Warning Message in 3D. Then you know whitch Object was the Culprit.
Ingolf Sundfør, Bricklayer, Author of several Real Life Problem Solving Books for Archicaddicts in Norway.
PC/i7/W11/ArchiCAD 6.5-27
