2017-05-04 09:17 PM
Solved! Go to Solution.
2018-01-16 10:57 PM
2017-06-27 05:38 PM
2017-06-28 08:51 AM
SenecaDesignLLC wrote:I've been looking at those multi-port adapters. Which one are you using, and have you found any downsides? Comments on some adapters report that they get quite hot (for the pass-through charging). I also suspect the ability to charge through the USB ports is limited.
that being said, i have one adapter, it has hdmi, 3usb ports and a card reader. so far it works perfect and leaves me with two other thunderbolt 3 ports while i charge, but i can charge through the adapter as well if i want.
2017-06-28 03:19 PM
2017-06-28 03:32 PM
2018-01-04 06:55 PM
2018-01-16 10:57 PM
2018-02-01 10:33 PM
