How to delete X ref Layers imported from a autocad file
Hello Everyone,
I am having a problem with my Layers.
At the beginning of my project, I imported a dwg file in a Worksheet, using 'Attach X ref' . (See Fig-1)
After completion of the modeling, I deleted that file. But Layers from dwg file still existing in my layer as 'X ref Layer. (See Fig-2) I failed to delete those layers manually because The delete option is inactive now. It's really annoying.
Can you please suggest me a way to delete those Layers?
1 Solution
You should be able to select all those XREF Layers and delete them in either the Layer Settings Dialog or in the Attribute Manager.
In the future, you are better off using the Drawing Tool to place DWG files in your project. That way attributes coming from the DWG file (Fills, Lines Types, Layers) do not become part of the attribute set of the Project, either.
Go to post
4 Replies 4
jl_lt
Ace
Hi Mr. Avishiplu, if you are using the Cad file as a guide for modeling, i recommend using the "place external drawing" which you can find in the same menu instead of Xref, and placing them in a worksheet, which you can later reference using the trace tool. This way you wont need to deal with layers in your file, but you can still control the visualization of the placed drawing.
Dear Laszlo Nagy
Thanks for ur Solution & Suggestion. Although The layer Settings Dialogue didn't work, the attribute Manager worked fine.
loann_vu
If that missing xref also had missing attributes, then instead of deleting the layers in the Attribute Manager, I would just make a dummy xref file with the exact name as the missing xref. Then I would Attach that xref. Then, Detach that xref, along with all associated attributes. That would take care of the layers and anything else that came along with it.
