2023-09-22 04:55 AM - edited 2023-09-22 04:56 AM
In File Explorer, I've noticed an inconsistent behavior when right-clicking on PLN files to view Properties. Specifically, some files display an Info & Preview tab, while others don't.
To investigate, I've had team members on different PCs, working with varying files and Archicad versions, send me screenshots. Despite this, I haven't been able to identify a pattern to determine whether this is tied to the file itself, system settings, or user configurations.
Does anyone have insights on how to consistently get the Info & Preview tab to show for all PLN files?
2023-09-22 05:18 AM
If it is different files on the same machine (same network location), then I am not sure.
If it is happening to all files on the same machine then I am not sure if this will work or not, but it could be worth a try.
It won't harm anything.
In File Explorer go to the Archicad Program folder.
In there you will see a folder for "Graphisoft Shell Extension'.
In there you will see a 'Register.bat' file.
Double click it to run it.
A window will briefly open and the file will run.
Try the properties now.
You may need to restart the machine.
But as I mentioned, I am not sure if that will solve the problem.
