Inconsistent Display of 'Info & Preview' Tab for PLN Files in File Explorer
In File Explorer, I've noticed an inconsistent behavior when right-clicking on PLN files to view Properties. Specifically, some files display an Info & Preview tab, while others don't.
To investigate, I've had team members on different PCs, working with varying files and Archicad versions, send me screenshots. Despite this, I haven't been able to identify a pattern to determine whether this is tied to the file itself, system settings, or user configurations.
Does anyone have insights on how to consistently get the Info & Preview tab to show for all PLN files?
06e6aeb2-b8ea-4b7f-a440-313687ad6d87.jpg7babe1b4-16bf-47dc-b746-a6d2f12edea1.jpg9e3c4f29-63b2-4111-a2d1-95bbe3398444.jpg6199dd51-0367-4e7b-912e-d98ab57bb328.jpg
GRAPHISOFT Certified BIM Manager | Senior BIM Specialist | LinkedIn
ARCHICAD 18-28 | BIMcloud | CI Tools | Grasshopper - Rhino | CloudCompare | Bluebeam
Australia & New Zealand
Windows 11 Business | Intel Core i9-13950HX @2.2GHZ | 64Gb RAM | 2x Samsung S27F350 1920x1080 60Hz | Nvidia RTX 4000 Ada Generation Laptop GPU (12Gb)
If it is different files on the same machine (same network location), then I am not sure.
If it is happening to all files on the same machine then I am not sure if this will work or not, but it could be worth a try.
It won't harm anything.
In File Explorer go to the Archicad Program folder.
In there you will see a folder for "Graphisoft Shell Extension'.
In there you will see a 'Register.bat' file.
Double click it to run it.
A window will briefly open and the file will run.
Try the properties now.
You may need to restart the machine.
But as I mentioned, I am not sure if that will solve the problem.
