Installation & update
Instal older version 12-17
Sergiusz Tomiczek
Hello
I need to install an older versionof ArchiCad 17 to 12 US/GB/POL, and I can't find the link on the Graphisoft webside . Does anyone know where I can find it?
Thx
Operating system used: Windows 12-17
11 REPLIES 11
Why do you need the older versions?
You don't need them to open an old file.
vistasp
For versions prior to v.18, you have to contact GS.
https://support.graphisoft.com/hc/en-us/articles/21118454283921-Download-a-legacy-version-of-Archica...
= v i s t a s p =
bT Square Peg
https://www.btsquarepeg.com
Because the person who works with me, has version 12 and he can't open it.
thx
So you work in 17 and you need to save back to 12 for your colleague?
If so you will need to install 16, 15, 14 & 13 to be able to save back to 12 one version at a time.
The language version (US/GB/POL) should not be important when converting the file, but you will only be able to run the language version that your license supports.
You will need the original CD/DVD installation disc as these are not available on line that I am aware of.
Or contact your local distributor as mentioned, and hopefully they can help.
Hello Barry,
I have an AC10 project that I need to modify. What is the easiest way to open this file?
I'm using AC28 now.
Thx,
GƔbor
Versions 6.5 to 28, AMD Ryzen 9 3900x, 32GB ram, GeForce RTX 2070 super, Windows 10
@Gabor Szelei wrote:
Hello Barry,
I'm using AC28 now.
From memory you need version 26 or older as that can open version 10 files.
Then save and open in 28.
27 & 28 can only open back to version 18 I think.
so, you say AC26 can open AC10 project... wow!
I didn't think so... I'll try it right away, I have AC26 installed on my computer!
thank you very much for the information
GƔbor
Lee Hankins
This link should give you more information on which versions of Archicad can open which legacy versions, it's near the bottom of the page
https://community.graphisoft.com/t5/Licensing/Archicad-File-and-Protection-Key-compatibility/ta-p/30...
File convertors for older versions are available here
https://community.graphisoft.com/t5/Project-data-BIM/Converting-old-Archicad-Files/ta-p/303492
Lee Hankins
ArchiCAD 4.5 - Archicad 29
macOS Tahoe (26.0)
Setup info provided by author
