Install
I can't install ArhiCAD, he can't find need JVM. I don't know, what to do. Please, help!
11 Replies 11
What is the exact error message you're getting? By the sound of what you're saying it sounds like Java Virtual Machine isn't installed on your computer, try getting that from http://www.sun.com , installing it, and then retrying the ArchiCAD installation.
HTH,
Dan
HTH,
Dan
It's writing;"I can't find need JVM.Please rerun once more. Point to option -is;javahome<JAVA HOME DIR> That's all.Thanks.
Djordje
Remove any Java that you already might have on your machine and start again.
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
I am also having a Java related error when attempting to install. I get this message:
java.lang.NoClassDefFoundError:runException in thread "Main"
I have removed Java and reinstalled it. I don't get this problem with other computers, only this one. Help.
Intel Pentium 4 2.4GHz 512M RAM Windows 2000 Pro SP4
I have the same problem. I tried to uninstall the java 1.5 update 11 and install other version, but it didn't work.
somebody help me?
Can nobody help me?
Djordje
_Icaro wrote:
Can nobody help me?
OS?
Archicad?
Djordje
HP Omen
Problem:
ArquiCAD 10
When I try to install the program I obtain that message:
java.lang.NoClassDefFoundError: run Exception in thread "main"
Computer configuration:
Windows XP
AMD Athlon 2600 1.91 GHz
768 MB RAM
HD 80 GB
Edit: Gforce 64 MB
Tks
Djordje
Check
http://www.graphisoft.com/support/archicad/system_requirements/
Your computer is not strong enough for Archicad.
Also, do the Windows update.
Djordje
HP Omen
