Installation & update
Installation of older builds of AC 15
Hi everyone, I'm new on this forum
I have AC 15 (Norwegian version build 3267) on DVD
I would like to use the Add-On: 3D Studio In that only works up to build 3003
http://www.graphisoft.com/support/archicad/downloads/ac15/INT.html
Is it possible to download a full version with this build, or "downgrade" the build to 3003 after installing 3267.
Appreciate any help with this
As far as I know the add-on was made for build 3003 but it should work with later hotfixes.
The hotfixes will also update the add-ons if they are installed when the hotfix is run.
The latest hotfix for 15 is hotfix 4 - build 3898.
So if your add-on doesn't run then go to the HELP menu and check for updates.
Download the latest one and install it.
This will update your add-on too.
GS have just released hotfix 5 for version 15 - build 4038.
