2016-09-15
03:47 AM
2024-03-22
08:15 AM
Aruzhan Hamar
2016-09-15 04:19 PM
2016-09-21 07:22 AM
2016-09-28 03:49 PM
2017-02-17 05:59 PM
KatalinBorszeki wrote:
Hi!
When the installer doesn't start at all, there is a high probability that the installed Java is not compatible with the installer.
Could you please try to remove all Java versions from the computer and then install the suggested one? http://www.graphisoft.com/downloads/java.html
If it doesn't help, could you please upload a video about the phenomenon? You can use the following link:
https://graphisoft.sharefile.com/r-r1c193d0eb7d4778b
If you are sure that you are using the right Java version, could you please upload a video as well? Please use the same upload link and PM me when the video is up. Thanks, k
Köszi,
Tamás
2017-03-20 02:15 AM
