Red
Interactive Schedule
I'm having problems setting up a schedule with this criteria.
Basically I'm wanting the schedule to only select certain objects and list the following.
1. Objectname (only certain objects not everyone that is in the drawing)
2. Layer of that object
3. Story that the object is on
4. ID of the object
I have no use for any of the parameters within the objects.
Thanks,
Red
i7 8700k
ROG Strix Z390-E MoBo
64gb RAM
EVGA GeForce GTX 2080
_______________________
http://www.facebook.com/flatcreekdesignstn
http://www.sraarchitects.biz
AC6 to Current
6 Replies 6
David Larrew
4. ID of the object
It is possible...
1. Set "Object Type" and "Object Name" under the "General" tab.
2/3/4. Select (check) "Layer", "Floor (Story)", and "ID" under the "Fields" tab.
David Larrew, AIA, GDLA, GSRC
a r c h i S O L U T I O N S
WIN7-10/ OSX 10.15.7
AC 5.1-25 USA
Red
Under the general tab how do you set it up to look for certain objects. I see where you can go into additional parameters and have it look at certain objects parameters.
Thanks,
Red
i7 8700k
64gb RAM
AC6 to Current
Red
After a few minutes of pulling my hair out I figured it out. Thanks David for your help.
Thanks,
Red
i7 8700k
64gb RAM
AC6 to Current
Red
Unless I have overlooked it can you also have it to show the objects link?
Thanks,
Red
i7 8700k
64gb RAM
AC6 to Current
By link do you mean the path in the file system to the actual object (or the PLA containing it)? If so, nope, AFAIK there isn't a way to show that.
AC 29 USA and earlier   •   hardware key   •   macOS Tahoe 26.5.2 MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
Red
Im referring to the link for BOMs. (Properties)
Thanks,
Red
i7 8700k
64gb RAM
AC6 to Current
