Issue with the Dimensioning
Hey,
I have a very annoying problem. My dimensioning is crazy, but only the dimensions from door axis.
I tried to find the issue, first it happens all the time when i published dwg files through the publisher....
Now i have the problem that some layers will activate or deactivate themselves for no reason and i think as a result the dimensions will go anywhere.
Have anyone a solution for this, it is really annoying to set the dimensions 100 times new.
thanks
2 Replies 2
jbArch
We are having this same issue. Until reading this post I had not fully realized that it happens only for dimensions to doors, and only after using the publisher to save DWG files.
Basically a handful of dimensions end up linked to the origin instead of to the door axis. (Other end of dimension string is linked to a gridline)
Going forward we will just create a temporary AC file prior to publishing a DWG, and then discard afterwards. But this definitely seems like a bug that should be addressed.
The user experiencing this issue is on Mac OS High Sierra, AC21 build 5010.
AC 21 (8002) & 22 USA
Mac OSX 10.14.5 on MacBook Pro 2.3GHz Intel i7, 16GB Ram, NVIDIA GeForce GT 750M 2GB VRAM, 500GB SSD
I have a similar issue happening also on AC24 even after open and repair. is this a confirmed bug?
