[JAVA jre 1more time]problem persist after jre1.4.2_05 inst
Hi *,
I have a ADM athlon(tm) xp 2600+ 2.13 GHz 256 mb di ram(in next days I'll upgrade it to 1gb) I'm try to install Archicad 9.
I've no java re installed, during the setup the installer take some time to install the jre after some second it's poop up the popular forum error "jre old version installed please install new version".I've close the installer, I've checked if the current user has admin right and it has, I've looked on the installed application and jre 1.4.2_05 appear installed.
So it's seems that the installer correctly install the jre but then fail to detect it, the problem persist also if I've restarted the pc.
Any Idea.
Thanks
this this the content for the log file(I've looked around google it seems to be a common problem but no fix found)
(10-ott-2005 23.06.06), Install, com.installshield.product.service.product.PureJavaProductServiceImpl$Installer, err, ProductException: (error code = 601; message="JVM non trovata")
STACK_TRACE: 8
at com.installshield.product.actions.JVMResolution.install(JVMResolution.java:171)
at com.installshield.product.service.product.PureJavaProductServiceImpl$InstallProduct.checkUninstallerJVMResolution(PureJavaProductServiceImpl.java:4793)
at com.installshield.product.service.product.PureJavaProductServiceImpl$InstallProduct.install(PureJavaProductServiceImpl.java:4554)
at com.installshield.product.service.product.PureJavaProductServiceImpl$Installer.execute(PureJavaProductServiceImpl.java:3758)
at com.installshield.wizard.service.AsynchronousOperation.run(AsynchronousOperation.java:41)
at java.lang.Thread.run(Unknown Source)
Djordje
You do have some version of probably Microsoft Java installed; try to find and clean it before the installation.
There were messages by Laszlo Nagy on old Java problems; try a Search with Java keyword and laszlonagy as the author.
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
