2010-10-22 08:22 PM
2010-10-25 07:50 PM
2010-10-25 07:54 PM
Erika wrote:Me too! Perhaps a bug? I'm using AC14 3269 INT FULL.
I am surprised by my results.
2010-10-26 02:54 PM
2010-10-26 11:06 PM
David wrote:New & Reset All is often used to rule out corrupt settings if ArchiCAD starts crashing or behaving oddly. It seems to me that will be a support problem if old (corrupted) settings are perpetuated.
I get the same result as Erika on New & Reset All: the ArchiCAD template loads, the Work Environment is not changed. (This is to me correct behavior.)
2010-10-27 02:09 AM
2010-10-27 09:02 AM
Erika wrote:Yep - that's the answer. Well spotted!
Ralph & David,
What I am finding is that the WE defaults to whichever WE I have set to be the default WE. I tested this back to 10.
Ralph, is your default WE the AC out of the box WE?
2010-10-27 09:55 AM
Ralph wrote:Erika wrote:New and Reset should return everything (including the Work Environment) to factory settings. Keyboard shortcuts, palette positions, etc will all revert to the original shipping defaults.
A new & reset will result in the default AC template file being the open active pln but with your most recent active WE still active.
2010-10-27 09:57 AM
David wrote:Yes!!! I did that! That was my first action. But it didnt change anything ..
Wendy:
You should try changing the Work Environment to Standard Profile 13 (I hope there is an obvious translation of this to Greek).
David
2010-10-29 11:05 AM
2010-11-05 09:42 AM
Achille wrote:I don't know I'm so confused! I had to re insert the shortcuts and now it works. I always work on English US keyboard though and when I switch to Greek It always works.
are you having a problem like the one described here:http://archicad-talk.graphisoft.com/viewtopic.php?t=30568 ?
Some of the issues i described have been solved now with OSX 10.6.4, but some still persist...
for example option+G for suspending groups only works with the US/UK keyboard and not with the Greek one...
