Installation & update
Large-ish 3D model vanishes in 3D window HELP!
Karl Barker
In the 3D window, if a largish Archicad 16 model, I am having a major issue where if I have just the right sized marquee, I can make my model disappear partially with a live cut plane. If the marquee is smaller, then no problems, the model is fine, if the marquee is bigger, no model at all.
I have the latest build of Lion, latest AC16 build, a 1GIG graphics card (of note it is even worse on a 1/2 GIG graphics card.
Below are some images of what is happening.
Anyone else ahd the issue, or got any ideas to work around?
I ahve also manually turned antianalysing on, but tried on a machine without the antianalising on and got the same result.
Karl Barker.
27" Macbook Pro, M4 Max
48 Gig Ram
Mac OSX 26
AC 5.5 - AC29 (NZE)
Karl Barker
More views:
Karl Barker.
48 Gig Ram
Mac OSX 26
AC 5.5 - AC29 (NZE)
David Maudlin
Karl:
This looks like the bug described here:
Bugs/Model cut in 3D
HTH
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
AC29 USA Perpetual • Mac mini M4 Pro OSX15 | 64 gb ram • MacBook Pro M3 Pro | 36 gb ram OSX14
