alemanda
Layers list
Getting quickly the desired layer by typing first letters/numbers of the layer name works only if the first two letters/numbers are different.
In my template I use numbers to identify layers ...
it happens that typing 180 in quick sequence I get the layer "180 ... " while typing quickly 117 I get first the layer 100, than typing again I get 101 ... and so on ...
eng. Alessandro Mandala - Italy
AC27 latest hotfix
Win 11 Pro 64bit
Ultra 9 275HX 64GB GeForce RTX 5070ti
7 Replies 7
mikas
Typing quickly 0, 00 and 000 gives me the following (see attachments) results with AC 19. It seems it works a little bit differently with me. If I correctly understood what you meant.
AC28, Rhino8+Grasshopper, TwinMotionMac Pro 6,1 E5-1650v2-3,5GHz/128GB/eGPU:6800XT/11.6.5 • HP Z4/Xeon W-2195/256GB/RTX4080FE 16GB/W11ProWS
alemanda
In Ac19 it worked properly. I mean - with an object/element selected - if i typed 117 I got the layer 117.
AC27 latest hotfix
Win 11 Pro 64bit
mikas
I didn't realize you meant AC 21, sorry. And my attachment was wrong too. Third image should show only 000 layer selected.
mikas
AC 21 (FIN) seems to work correctly, I think. Typing 1 and 1 in a row gets this. I think this is what should happen, is it?
alemanda
Mikas,
I confirm that I cannot get at first attempt any layer whose name starts with 11 ... for example if the elements belongs to layer 702 and I want to put it into the layer 118, I cannot do it typing quickly 118 ... doing that I get 180 simply because the second "1" type is not recognized somehow ...
AC27 latest hotfix
Win 11 Pro 64bit
mikas
I would try this with windows 10, but I lost my just recently downloaded AC21 installer exe-file somewhere. I am not very good with windows yet, I am a beginner with this WIN-world.
My idea was to rule out a win-MacOS difference with AC21, something graphisoft surely would be able to straighten out quickly enough.
I'll have to try again to install. Or maybe somebody else can do this test quicker than me.
mikas
Allright, I´ve got win10Pro+AC21 working in my HP now. It's weird with layers shortcuts. They do not correspond with what I get with my Mac. Double digit keyboard presses do not do the same with Win10 Pro and macOS10.12
