Line Types
Is there a way to manage Line types by selecting a group. Currently the element attributes manager only allows me to select one line at a time then delete that line. There must be a beter way than this. Any help would be great.
4 Replies 4
TomWaltz
Do you mean the Line Type editor (which only shows linetypes) or the Attribute Manager (which shows linetypes in addition to layers, materials, zones, etc)?
Tom Waltz
I meant the Options tab, then Elements Attributes, Line types. Can you select more that one line to delete a group? There is a button in this dialog box for selecting a line type to edit, rename, delete, but i can only delete one at a time. What a drag. Can this be done by selecting more than one?
TomWaltz
That's what I thought.
If you go to the Attribute Manager (it should be near the Linetypes Options on your drop down menu) , it will let you select as many as you want and delete them all at once.
Tom Waltz
That did the trick.
Thank you Tom.
