MarinRacic
Logitech V500 mouse?
Has anyone used it with ArchiCAD? I wonder what it's like regarding it's sensor replacement of mouse wheel. Is it as good as the good ol' wheel or better?
MBPro Retina 2.7i7/16GB/SSD
AC ...20/21
www.3Dart.hr
15 Replies 15
Dwight
Okay. They do BOTH, then.
Where do you buy your tights?
Dwight Atkinson
ci-JoshOs
I don't. They are part of my thighs. Each winter i spend a painful few hours scratching myself on rocks and things to shed them, and a new set grows within days!
Incidently, i'm just hacking my way through your book at the moment and i have a question, can i email you or something?
Josh Osborne - Central Innovation
Mac Mini
Dwight
Be quick - I'm off to OZ in two hours.
Dwight Atkinson
ci-JoshOs
I have a client who is using the 'wall-with-big-texture-on-it-to-make-a-photo-background' method, but he is using it in an animation, so the camera needs to move around. This means that he has a wall(OK, cyclorama) going all the way around. It is also quite high, and he is running into the issue of the wall casting a shadow over the whole model.
As you can imagine, this doesn't look so great, but he doesn't want to change the angle of the sun, so i'm stuck. He has tried putting in fill lighting to reduce the shadow, but it affects all his other shadow casting.
What would you recommend(besides 3DS Max)? Also, is Cyclorama the name of a nightclub in some 80s movie?
Mac Mini
Dwight
1: Cut a hole in the wall for the sun to shine thru.
OR:
2: Turn that circular wall into a GDL object.
in the script : SHADOW OFF
Then it doesn't cast a shadow.
Check with other GDL experts for the modern way to do this since I only vaguely remember it in a Matthew Lohden sort-of-way.
Dwight Atkinson
ci-JoshOs
That sounds good.
Thanks for the help
(ohmygoshohmygosh, i can't beleive i actually spoke(well, typed) with the real Dwight Atkinson! I am never going to wash this hand again!)
Mac Mini
