Installation & update
Mac G5 Recommendations
I am contemplating purchasing a new computer. I am debating on buying the low end G5 or the 1.25 ghz G4. There is about a $400 price difference. Does anyone that has used the G5 recommend buying it? Are there are bugs? Is it worth the extra $400 in the long run? What are your thoughts? Also, I heard that sometime real soon apple was going to come out with a new model for the G5 and stop making the 1.6 ghz and replace it with a single 1.8 ghz for the same price ($1800). Has anyone heard anything about that?
9 REPLIES 9
Hi Mike,
Your return on investment will be alot greater on a G5 than it will on a G4. The reason for this is that the G5 will support 64bit processing where as the G4 won't.
Currently the G5 running Panther (OSx.3) and AC only run in 32 bit but at some point (maybe years) they will go to 64bit and therefore there will be a massive speed jump.
I would certainly go for a G5 and the 1.8 dual is much better than the 1.6 if you can stretch your budget a little more.
Bite the bullet and buy the G5.. you won't regret it! I had the same dillema a month ago. I was watching a maxed out G4 dual 1.25 and a G5 dual 2.0gHz on eBay.. I paid $2600 for the G5 and I can tell you it has been exceptional. I didn't realize how much I multitask! I am actually thinking about buying a second monitor to utilize this new found speed boost!
+pablo
Without a doubt go with the G5 its light years quicker than the G4 machines. Its great and will be better once more software especially ArchiCAD is rewritten for it.
Why dont you buy one of the refurbed Virginia Tech G5's and own a piece of Apple History
There should also be new Powermacs out in the next week or two you may pick up an older model cheaper.
The Xserve G5 would look great in an architect's office. Of course ArchiCAD will not take advantage of it, but network rendering programs such as Cinema4D will.
xRack
Start with ( 8 ) xServers G5
• Dual 2GHz PowerPC G5's each
• 512MB DDR400 ECC SDRAM - 2x256
• 80GB ADM (1x80GB Serial ATA)
• Mac OS X Server, 10-seat License
Why not have a super computer at your desk?
What were those lottery numbers?
Aussie John
Unless you are getting a great deal on a G5 it is quite possible a new update is on the horizon (ie by end of month?)
Cheers John
[/size]
I hear rumors about a G5 "Quadra" - 4 processors in one box.
Aussie John
I read that too but I wouldnt put a sheep station on it happening too soon
Cheers John
[/size]
Dave Jochum
You Aussies and your sheep! What the heck is a sheep station?
Dave Jochum
J o c h u m A R C H I T E C T S http://www.jochumarchitects.com
MBP 16" (M1 Max) 64 GB•OS 15.3•AC 28 Silicon (latest build)
Aussie John
There used to be a saying that Australia [its economy] rode on the back of a sheep - ie sheep were valuable and wool drove the economy.
hence a sheep station (US substitute - cattle ranch) was once a valuable thing. Mind you a bale of wool sold the other day for US$ 5,000,000
Cheers John
[/size]
