‎2013-10-23
09:22 AM
‎2024-03-28
10:01 AM
Aruzhan Ilaikova
‎2013-11-23 09:13 AM
‎2013-11-24 09:27 AM
‎2013-11-25 08:23 AM
riccardo wrote:Try to run a full Repair Disk Permission in Disk utility on the Partition where you have OS X and ArchiCAD installed. After that hopefully you will be able to install the latest hotfix.
Now definitively AC 17 is dead, impossible to open it I have 3 works I can't modify, it's a tragedy. Every time I try to run it close before I can choose what's the file to open and start the bug description.
Could be Mavericks the guilty?
Also last hot fix cannot be installed, I changed permissions of AC 17 folder but no running possibility...
Thanks for your help
‎2013-12-05 04:37 PM
‎2013-12-05 04:42 PM
oliverl wrote:Unfortunately the update cycle of ArchiCAD 11 has been already ended, as a result we are not planning to publish any updates that would help to run AC 11 on Mavericks.
Hey,
We are looking to upgrade to mavericks but we're still using Archicad 11. I understand it won't work at present due to technical limitations but I'm wondering if this is temporary until a hotfix/patch is introduced or whether it won't work full stop.
‎2013-12-06 10:58 AM
‎2014-01-03 12:27 AM
drh64 wrote:Daniel, was this case ever resolved?
There is a problem with open gl. Restoring my drive back to ML.
‎2014-01-03 01:20 AM
‎2014-01-04 09:43 PM
Karl wrote:Check for crash reports in Console. I discovered dozens of crashes happening during these operations from faulty QuickLook plugins. ArchiCAD was responsible for some of those, but not all of them. The latest hotfix seems to have corrected this. These plugin crashes were causing a substantial drain on performance (also Spotlight plugins) and removing the culprits made a big difference.
I've had a few issues with Mavericks on two machines that I'm finding lots of other people experience on the Apple forums. Finder and all file operations (open/save dialog appearance/population) are slower than in all prior versions of OS X. With my SSD, File Open dialogs (e.g.) appeared instantly in Mountain Lion and previous releases.. but now it can be up to 10 seconds. Ditto opening a Finder window, clicking on a folder and waiting for its contents to appear. 100's of people reporting, and no fix from Apple as of 10.9.1
‎2014-02-03 10:59 PM
