2013-12-20 08:51 PM
2013-12-20 09:07 PM
2013-12-20 10:27 PM
2013-12-21 12:24 AM
2013-12-21 07:38 AM
2014-01-03 07:54 PM
owen wrote:Does anyone had a chance to get in hand with MacBook Air (11-inch, Mid 2013) and AC17?
I highly recommend the Macbook Airs .. should be perfectly capable of running medium sized projects, even large. I use an Air either docked in Target Disk mode to a MacPro or iMac when I need to run multiple sessions of ArchiCAD and other apps (e.g Revit via Parallels) however also use the Air 'normally' attached to a Cinema display and it is very snappy indeed.
The only real limit you may find will be the number of applications you can run simultaneously due to the 8GB RAM (machines i dock to have 16-32GB). This downside is somewhat reduced by the super fast application starts due to the SSDs … closing an app to start another doesn't involve much waiting😉
os
P.S I run a 3.5GB 50,000m2 Teamwork project on my Air quite regularly and never had any performance issues. Actually i find it faster for most things than my other (non-SSD) machines except for activities helped by multi-core processors (e.g section rebuilds)
2014-01-04 03:49 AM
2014-01-24 08:58 AM
RivaRivo wrote:Glad someone found that article
I was wondering to get myself a MBA 11".
This story could be a mind changer.
And this testimonial is also sound promising:
os
