Installation & update
Mojave upgrade and AC20...
Llian
Anyone having any issue with Mojave upgrade and AC20 ?
Lilian Seow LEED AP | cSBA | CAPM | PMP
AC 29 USA FULL | Windows 11 Enterprise i5 3.10GHz | Archicad-user since 1994!
4 REPLIES 4
DGSketcher
Legend
Probably if they have upgraded... https://helpcenter.graphisoft.com/knowledgebase/84821/
In short - AC20 is not supported on Mojave
Hi Lilian,
You've been here long enough to know to just search for your answer before starting a new thread. 🙂
Besides the Graphisoft resource page that DGSketcher provided for you, searching Mojave gives at least these threads:
https://archicad-talk.graphisoft.com/viewtopic.php?f=13&t=63149
https://archicad-talk.graphisoft.com/viewtopic.php?f=5&t=63317
https://archicad-talk.graphisoft.com/viewtopic.php?f=5&t=63257
If AC 22 people have run into issues with Mojave, there would only be more (one would assume) with AC 20 which is not officially supported.
Llian
Hi Karl…I did make a search before posting…and I didn't get results. Thanks anyway for your reply. Lilian
No problem. If you click the magnifying glass in the black bar at the top of every page here and just type 'Mojave' you'll get all of the posts. 🙂
