Muscle memory and key shortcut "option cmd D" OSX
Tomba
Help
My favorite keyboard shortcut Drag a Copy "option cmd D" won't work on Mac Big Sur. It's also the shortcut to show the dock in Big Sur. I tried to switch the dock shortcut off hoping that might work but can't find a way to do this on OSX. I could change the shortcut in Archicad but my muscle memory is set.
Any Ideas?
Many Thanks
Stuart
furtonb
Go to System Preferences / Keyboard / Shortcuts, then under Launchpad untick "Turn Dock Hiding On/Off".
odv.hu | actively using: AC25-27 INT | Rhino6-8 | macOS @ apple silicon / win10 x64
Guru
There are several posts about this, as well as a help article that brings up this issue.
Please use the Label funtion when making a post as if will make it easier others who run into similar issues to find related posts.
Ling.
felcunha
Just go to System preferences -> Keyboard, click on the shortcuts tab and then click on the alt-cmd-D. It will highlight.
Digit the shortcut you want.
That's it!
Felipe Ribeiro Cunha
AC 26, macOS Monterey
