Installation & update
'N" sided polygons, stars
This is a feature I am surprised I don't already see in ArchiCAD.
Basically, the first option is to make an equilateral polygon with a nominal number of sides. An enhancement would be to make a equilateral "star" where you could specify the number of points and either an exterior and interior radius or the angle of deviation from tangency.
12 REPLIES 12
Until then, use this.
Thanks, that works for triangles to octagons, but I want a polyline, not a library part.
I know, I know, some people are never satisfied. 😉
Explode it, then Unify the resulting lines.
Djordje
Ace
Draw a circle, set the magic wand to linear segments, type the number of segments, activate polyline tool, click on the circle with the magic wand.
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
Hmm, thanks. What a bizarre way to draw.
Djordje
Ace
I would not call this drawing.
You can use the same technique for any polygonal element.
Djordje
HP Omen
Sounds like a job for MaxonForm.
Or a ninja.
Think Like a Spec Writer
AC4.55 through 27 / USA AC27-5060 USA
Rhino 8 Mac
MacOS 14.6
Aussie John
Not much of a big deal. Pentagon and Stars arent a regular part of my daily drawings routine.
Cheers John
[/size]
yeah, well try modelling a building for the occult, and do it without stars and pentagons..
